mshop_order_base_product_attr
cnoelker
Post by cnoelker » 15 Jul 2020, 12:06
no problem with it, but I am curious:
Is there some reason why all values in the column 'value' of the table mshop_order_base_product_attr are surrounded by quotes?
E.g. the column contains:
"1234"
"size_xs"
Claudia
Re: mshop_order_base_product_attr
Post by aimeos » 15 Jul 2020, 12:30
The "value" column is JSON encoded.
cnoelker
Post by cnoelker » 15 Jul 2020, 12:43
Ah, then it makes sense. I always have one value inside it, only.
Thanks!
Claudia
Post by aimeos » 15 Jul 2020, 12:52
Can be also several values and it depends on the attribute type
cnoelker
Post by cnoelker » 15 Jul 2020, 13:02
Which type has more than one value? I am currently seeing only custom and variant attributes in that table.
Post by aimeos » 15 Jul 2020, 13:10
Mainly service attribute or if you need to store lists or maps of custom values.
