Replacing the body-standard template
cnoelker
Post by cnoelker » 21 Aug 2020, 14:16
I need to replace the template-body of the basket. According to the documentation
https://aimeos.org/docs/Configuration/C ... plate-body
I set this in the TypoScript:
plugin.tx_aimeos.settings.client.html.basket.standard.template-body = basket/standard/body-statistics
The file is names body-statistics.php and it is available at the referenced location. However, the file is ignored. What's wrong?
For a test, I renamed the file to body-standard.php in the same directory. This works.
However, I want to keep the default basket and provide an additional statistics view. Therefore, the second template file is needed.
Claudia
Re: Replacing the body-standard template
Post by aimeos » 21 Aug 2020, 19:44
You've left out one ".standard" part in the path if you compare the string in the documentation with yours.
cnoelker
Post by cnoelker » 22 Aug 2020, 09:46
Oh, two ".standard" in there! Thank you, I overlooked that one.
