Reduce search word length to two digits
boettner
Post by boettner » 21 Sep 2020, 14:18
how can I reduce the search word length to two digits) I found the parameter in autocomplete but there must be another one for the actual query since I don´t get results yet.
Robert.
Re: Reduce search word length to two digits
Post by aimeos » 21 Sep 2020, 14:26
You have to change the settings in the mysql.cnf file of you DB server to get this working:
https://aimeos.org/docs/Administrators/ ... mum_length
boettner
Post by boettner » 21 Sep 2020, 14:28
Great thanks for this ultra-fast reply!
boettner
Post by boettner » 22 Sep 2020, 14:45
Hi again,
ft_min_word_len is set correctly:
mysql> show VARIABLES LIKE '%ft_min_w%';
| Variable_name   | Value |
| ft_min_word_len | 2     |
1 row in set (0.00 sec)
I rebuilt the mshop_index_text table by deleting it and setting it up by the update job after not having enough rights do it in another way. Afterwards I rebuilt the index by running the product index job.
An autocomplete search is issued after two entered characters but no result gets returned in frontend.
If I check it via DB I get results:
SELECT * FROM `mshop_index_text` WHERE `content` LIKE '%F9%'
Do you have any suggestion how to debug this further?
boettner
Post by boettner » 22 Sep 2020, 14:47
Forgot:
SELECT * FROM mshop_index_text
        WHERE MATCH (content)
        AGAINST ('F9');
This returned no results.
Post by aimeos » 23 Sep 2020, 14:35
MySQL full text search is very different from a LIKE query and it may handle words with numbers differently.
boettner
Post by boettner » 23 Sep 2020, 14:39
Thanks for your answer. I know:
boettner wrote: 22 Sep 2020, 14:47 Forgot:
        AGAINST ('F9');
Also searching e.g. for "TW" returns no results. Do have by chance an idea how to track that down?
Post by aimeos » 23 Sep 2020, 14:55
If those two letter words are too often used in the text, they will be ignored.
Another problem could be that they may be in the MySQL stopwords list.
