[Solved] What can "params" really do?
rowild
Post by rowild » 20 Oct 2020, 22:18
In the filter tree templates there is this code section:
<?php if( count( $item->getChildren() ) > 0 ) : ?>
	<?= $this->partial(
		$this->config(
			'client/html/catalog/filter/partials/tree',
			'catalog/filter/navigation/tree-partial-standard'
			'nodes' => $item->getChildren(),
			'path' => $this->get( 'path', map() ),
			'level' => $this->get( 'level', 0 ) + 1,
			'params' => $this->get( 'params', [] ).     // <== how can I pass on stuff?
<?php endif; ?>
In my setup there is a property, which I can get via
$item->get['css-class']
Can i use the params attribute to pass it on to the template? And if so, how?
(As an object like
{ "cssClass": $item->get['css-class'] }
would be great...)
Re: What can "params" really do?
Post by aimeos » 21 Oct 2020, 10:08
Don't use the "params" argument for passing additional data to the partial because "params" is used to build the URLs.
Instead, you can pass additional data using an additional arbitrary name, e.g.:
	<?= $this->partial(
		$this->config(
			'params' => $this->get( 'params', [] ),
			'css' => $item->getConfig()
Then, the data will be available in the partial using
$this->get( 'css', [] );
rowild
Post by rowild » 31 Oct 2020, 08:56
Thank you!!
