No catalog node
markus.suess@mbit.at
No catalog node
Post by markus.suess@mbit.at » 11 Nov 2020, 15:13
I still got the issue when installing version 20.10.2
I can run the database import, it says everything is fine, but i have no catagories or product afterwards.
Frontend says
No catalog node for ID ""
Re: No catalog node
Post by aimeos » 12 Nov 2020, 07:37
Check if you ran:
The --option will add the demo data.
Re: No catalog node
Post by markus.suess@mbit.at » 12 Nov 2020, 10:10
Sorry I forgot:
I am on Ubuntu and its a TYPO3 Installation
Re: No catalog node
Post by aimeos » 13 Nov 2020, 13:11
In the extension settings of TYPO3 for Aimeos, you can select to overwrite (create) demo data. Then, you have to execute the Aimeos update script in the extension manager once again to add the demo data.
Re: No catalog node
Post by markus.suess@mbit.at » 19 Nov 2020, 16:27
Thank you, works fine now.
