[Solved] How to delete a once added coupon again?
rowild
Post by rowild » 15 Nov 2020, 10:46
Adding a coupon works. But how can a customer delete the coupon from the basket again, in case (s)he decides differently?
In the "common/summary/detail-standard.php/" template, I set "$modify" to true. But there is another check
if( ( $product->getFlags() & \Aimeos\MShop\Order\Item\Base\Product\Base::FLAG_IMMUTABLE ) == 0 )
that disables vouchers from being removed again.
This has strange consequences, here a scenario:
- customer adds some products,
- customer adds coupon (assigned to one of those products)
- customer decides differently and deletes all products again (once all products are delete, the coupon does not show up either)
- customer adds 1 other product with no coupons assigned to it
- suddenly the coupon appears again (and reduces the price, even though it is assigned to another product)
Am I doing sth wrong? How can I prevent that?
Re: How to delete a once added coupon again?
Post by aimeos » 16 Nov 2020, 10:35
There's a button for deleting the added coupons in the basket standard component if a coupon has already been added. Check for the HTML code in the original template if you've overwritten that part already in your own template.
rowild
Post by rowild » 23 Nov 2020, 09:27
Thank you!
