Cannot install custom Aimeos extension
promptnet
Post by promptnet » 27 Nov 2020, 10:11
I use TYPO3 10.4 with composer and PHP 7.3 (Aimeos: 20.10.2).
Today I downloaded a custom extension: https://aimeos.org/extensions/
Then I tried to install this extension with composer but it did not work.
My folder structure:
  • root
    • packages
      • a custom extension which works, symlinked to public/typo3conf/ext
      • custom aimeos extension
    • public
      • typo3conf
        • ext
          • aimeos
          • other extensions
The installation seems to be okay - no error message. But it is not installed!?
What do I have to do?
Thanks for help,
Kurt
promptnet
Re: Cannot install custom Aimeos extension
Post by promptnet » 27 Nov 2020, 13:51
Sorry, while searching for the problem, I found out that the extension is installed within the main aimeos extension, and it works perfectly!?
But, what happens if I update the main aimeos extension? Do I lose the custom extension?
Thanks for an answer.
Post by aimeos » 29 Nov 2020, 13:47
In composer installations, the extensions are installed in the ./ext/ directory besides ./vendor/ and ./public/ and are not overwritten by composer if you update.
promptnet
Post by promptnet » 01 Dec 2020, 09:31
Ah, cool, thanks.
