Pdf in all paymantemails
Shopmister
Hey,
TYPO3 Version
10.4.12
Webserver
Apache
PHP Version
7.3.27-1~deb10u1
Database (Default)
MySQL 5.5.5-10.3.27-MariaDB-0+deb10u1
Application Context
Production
Operating System
Linux 4.19.0-9-amd64
Last Scheduler run
19-03-21 at 14:15, Duration 0 min, (started automatically)
i have the question how i can let send an automatically pdf in the mail. Not only by the paymantmethod "invoice".
and
Where i can set the ibandata/bankdata from supplier for the customer emails/pdffiles. Only in the template or in backend? Logical would be for me to set the ibandata in the supplierstab in backend, like the supplier adress and so. Maybe you guys can make it possible in the next update? or its possible about typoscript or something else?
I know the doku about the subpartthings, but some things arent maybe up to date, like here:
typo3-extension-f16/how-to-deactivate-p ... t3069.html
I dont have any idea what to do. I hope you can help me
TYPO3 Version
10.4.12
Webserver
Apache
PHP Version
7.3.27-1~deb10u1
Database (Default)
Application Context
Production
Operating System
Last Scheduler run
and
Re: Pdf in all paymantemails
PDFs are only generated for the payment related e-mails. If you want to add it to the delivery related e-mails, you would have to copy the PDF subpart from the payment e-mails to the delivery e-mails:Shopmister wrote: 19 Mar 2021, 13:39 i have the question how i can let send an automatically pdf in the mail. Not only by the paymantmethod "invoice".
- https://github.com/aimeos/ai-client-htm ... ayment/Pdf
- https://github.com/aimeos/ai-client-htm ... andard.php
You should add that to the template generating the PDF:Shopmister wrote: 19 Mar 2021, 13:39 Where i can set the ibandata/bankdata from supplier for the customer emails/pdffiles. Only in the template or in backend? Logical would be for me to set the ibandata in the supplierstab in backend, like the supplier adress and so. Maybe you guys can make it possible in the next update? or its possible about typoscript or something else?
You can make it configurable and add the details to the TSconfig field of the scheduler task.
Remember that the settings have to be added to the TSConfig field of the scheduler task, not to the frontend config.Shopmister wrote: 19 Mar 2021, 13:39 I know the doku about the subpartthings, but some things arent maybe up to date, like here:
Shopmister
I mean not in all mails. Only in all paymant related mails i want the pdf. Thats what i meanPDFs are only generated for the payment related e-mails. If you want to add it to the delivery related e-mails, you would have to copy the PDF subpart from the payment e-mails to the delivery e-mails:
I understand right? I have to add to the template. and if i want to can add it in the schedulertask, i need to make it configurable with php? Thens nothing for me, because im a nub in php ^^.You should add that to the template generating the PDF:
The PDF is currently restricted to payment status "authorized" and "received":Shopmister wrote: 22 Mar 2021, 15:00 I mean not in all mails. Only in all paymant related mails i want the pdf. Thats what i mean. or i missunderstood? Only at the paymant method invoice, a pdf is attached in the paymant related emails. And not at example for prepaymants.
https://github.com/aimeos/ai-client-htm ... hp#L71-L73
The pre-payment option sets the status to "pending", so no PDF is included there. I think we should remove that restriction in the next update.
Shopmister
Yes, that would be good. Maybe you guys can give the Supplier in backend, ibandata too. BEcause i think it makes much sence to give every supplier like the adressdata, the ibandata tooThe pre-payment option sets the status to "pending", so no PDF is included there. I think we should remove that restriction in the next update.
I tryed for now to write the Bankdata in the normal mail for the prepaymant in the de.po:
msgstr "Die Bestellung wird ausgeliefert sobald wir die Zahlung vollständig erhalten haben. Wenn Sie sich für Vorauskasse entschieden haben, überweisen Sie bitte den Betrag auf unser Bankkonto und geben die Bestellnummer %1$s als Referenz an. Folgend die Kontodaten auf das Sie das Geld überweisen können:
<table cellpadding="0.5" style="font-size: 8px">
<tr>
<td>Adresse und so</td>
<td>District court: </td>
<td>Bank: bankname Lala</td>
</tr>
<tr>
<td>Telephone: </td>
<td>Managing director: </td>
<td>IBAN:45435345345345345345 </td>
</tr>
<tr>
<td>E-Mail: </td>
<td>VAT ID: </td>
<td>BIC: </td>
</tr>
</table>
But no change in the email. Wich is the exactly part where i have to paste it? to have the bankdata in mail
Done and will be available in the next release.Shopmister wrote: 25 Mar 2021, 13:18Yes, that would be good.The pre-payment option sets the status to "pending", so no PDF is included there. I think we should remove that restriction in the next update.
Don't know if the supplier is the right place because usually, suppliers are no vendors. How do you use suppliers in Aimeos? Do you have several of them?Shopmister wrote: 25 Mar 2021, 13:18 Maybe you guys can give the Supplier in backend, ibandata too. BEcause i think it makes much sence to give every supplier like the adressdata, the ibandata too. Then it would be easy to have different ibandata for every supplier , and this automatically used in the pdf, would be perfect then
The .po files have to be transformed to binary Gettext MO files:Shopmister wrote: 25 Mar 2021, 13:18 I tryed for now to write the Bankdata in the normal mail for the prepaymant in the de.po:
msgfmt --statistics -c -o de de.pohttps://aimeos.org/docs/latest/developer/translations/
In TYPO3, you can also overwrite translations by TypoScript:
https://aimeos.org/docs/latest/typo3/cu ... anslations
and something like that in the TSConfig field of the scheduler task may work (keep care about the "\" character which might need escaping to "\\"):
i18n.de.0 {
domain = client
string ( The order is pending until we receive the final payment. If you\'ve chosen to pay in advance, please transfer the money to our bank account with the order ID %1$s as reference.
trans (
<tr>
</tr>
<tr>
</tr>
<tr>
<td>E-Mail: </td>
<td>VAT ID: </td>
<td>BIC: </td>
</tr>
</table>
Shopmister
Very great, thanks a lot!Done and will be available in the next release.
Do you have an idea when around the next update is planned? I was a few days to late with my question i think
I tryed to find out what exactly suppliers are. In German the word is "Lieferant" My result was suppliers/Lieferanten are firms they sell things to the customer. Yea i wanted to have in short term not a several but a view of them.Don't know if the supplier is the right place because usually, suppliers are no vendors. How do you use suppliers in Aimeos? Do you have several of them?
For AImeos are suppliers/Lieferanten no vendors i see. I thougt long about this theme. FOr me it was complicated ^^.
Whatts for Aimeos an Supplier/Lieferant? Whatts the plan behind.
I did it about typoscript:and something like that in the TSConfig field of the scheduler task may work (keep care about the "\" character which might need escaping to "\\"):
Much more easier
SO it works about the scheduler typoscript:
plugin.tx_aimeos.settings.i18n.de {
0 {
domain = client
string = The order is pending until we receive the final payment. If you've chosen to pay in advance, please transfer the money to our bank account with the order ID %1$s as reference.
trans = Die Bestellung wird ausgeliefert sobald wir die Zahlung vollstaendig erhalten haben. Wenn Sie sich fuer Vorauskasse entschieden haben, Ueberweisen Sie bitte den Betrag auf unser Bankkonto und geben die Bestellnummer %1$s als Referenz an. Folgend die Kontodaten auf das Sie das Geld überweisen können: Bankname ==> Bank Denzig Kontoinhaber ==> Inhaber IBAN ==> DE02303
No wondering: the "==>" is only because not more than one " " between words are allowed ^^.
A new 2020.10 release will be available in ca. six weeks.Shopmister wrote: 29 Mar 2021, 13:44 Do you have an idea when around the next update is planned? I was a few days to late with my question i think![]()
Suppliers are manufacturers or brands like Addidas for sneakers but you can use them for other entities like distributors too.Shopmister wrote: 29 Mar 2021, 13:44 Whatts for Aimeos an Supplier/Lieferant? Whatts the plan behind.
Multiple white spaces are collapsed in HTML and TCPDF converts the HTML code to PDF.Shopmister wrote: 29 Mar 2021, 13:44 No wondering: the "==>" is only because not more than one " " between words are allowed ^^.
