Stripe in the latest versions of Aimeos and TYPO3
crazyforester
Post by crazyforester » 30 Mar 2021, 09:12
Hi , we would like to use the latest Aimeos version 20 in the latest TYPO3 10. We have to use Stripe as payment option, but I see that Aimeos payment extension that contains Omnipay payment library is not available for TYPO3 10. Is there any other option to use Stripe as payment option?
thanks
Re: Stripe in the latest versions of Aimeos and TYPO3
Post by aimeos » 31 Mar 2021, 11:40
The aimeoscom/ai-payments extension offering Stripe support is only available if you install TYPO3 using composer. It has become impossible to offer an extension with the Omnipay payment drivers due to version conflicts with the packages included in the TYPO3 vendor folder from the TYPO3 ZIP file.
crazyforester
Post by crazyforester » 27 Jul 2021, 08:55
what is the right code to install aimeos_pay via composer
I have TYPO3 10.4.18 and aimeos 21.7.1 in ddev environtment
thanks
Post by aimeos » 27 Jul 2021, 09:03
composer req aimeos/ai-payments
You also need to install the Omnipay driver you want to use.
crazyforester
Post by crazyforester » 27 Jul 2021, 12:06
Many thanks
I would like to use only Stripe , so I suppose your code for ai-payments installation is enough
or I must try something like
composer req aimeos/ai-payments omnipay/stripe
thanks
Post by aimeos » 27 Jul 2021, 17:38
You need to install "omnipay/stripe" too.
