Scheduler: Jobs not selectable
michaels
Post by michaels » 21 Jul 2021, 19:51
I am using a fresh installation Typo3 9.5.28 and Aimos extention "Aimeos shop and e-commerce framework" 21.7.1.
The documentation says, I have to setup some scheduler-tasks using class "Aimos Shop advanced scheduler" and I have to select the jobs form the job list. The job list lists all possible jobs, but it is not possible to select one or more job with the mouse. The same behavior at "Sites", it is not possible to select the site "default".
I tried different browsers (actual Firefox 87, actual Chrome 92, old Firefox ESR).
TYPO3 Version: 9.5.28
Webserver: Apache/2.4.41 (Ubuntu)
PHP Version: 7.2.24-0ubuntu0.19.04.2
Database (Default): MySQL 5.5.5-10.3.29-MariaDB-0ubuntu0.20.04.1
What am I doing wrong?
Michael
ivanp
Re: Scheduler: Jobs not selectable
Post by ivanp » 21 Jul 2021, 20:50
I checked v21.7.1 in TYPO3 10.4.18: no problems.
Did you select the different jobs by clicking using the Ctrl button? (Select: Click+Ctrl)
michaels
Post by michaels » 22 Jul 2021, 06:23
Yes, I tried a single click and ctrl-click.
I tried an "empty" Firefox (no extentions): It is not possible to click or even to mark the text. It appears as if the event has been recognized but not evaluated.
Selections and multi-selections in other places, e.g. the selection of the "Static templates" in Typo3 works fine.
Post by aimeos » 22 Jul 2021, 07:10
Maybe it's a bug in the latest TYPO3 version. Does a previous TYPO3 release work?
michaels
Post by michaels » 22 Jul 2021, 11:16
A little bit crazy: I use a reverse proxy, access the Typo3 system via https and everything worked so far (frontend and backend). Now I have tried to access Typo3 and the scheduler configuration directly via http and the problem has disappeared.
Thanks for your help!
Michael
