Upgrade problem 2019.10 -> 2020.10
nvindice
Post by nvindice » 05 Aug 2021, 16:59
We have massive trouble with upgrading Aimeos on Typo3 v9.5.28 from Version 2019.10 -> 2020.10, managed via Composer.
As soon as the "aimeos" extension is activated, the Typo3 backend (and console) become unusable with the error message:
An exception occurred while executing 'SELECT `siteid`, `label`, `nleft`, `nright` FROM `mshop_locale_site` ORDER BY `nleft` ASC': Unknown column 'siteid' in 'field list'
We cannot run the aimeos database upgrade script because of this error. What can we do to fix this problem?
Re: Upgrade problem 2019.10 -> 2020.10
Post by aimeos » 06 Aug 2021, 06:47
We've backported a change from 2021 that should fix the problem. Can you install and test:
composer req aimeos/aimeos-typo3:2020.10.x-dev
Background: TCA had been extended to associate a site ID to BE users.
nvindice
Post by nvindice » 06 Aug 2021, 14:03
Worked, thanks alot!
