JQAdm Configuration problem in Typo3
nvindice
Post by nvindice » 25 Aug 2021, 11:43
Hi, I'm trying to configure a custom backend navigation with 2021.07 on Typo3 v10. The configuration array looks like this: https://github.com/aimeos/ai-admin-jqad ... navbar.php
Unfortunately, I cannot find a way to pass an empty string as an index with Typo3 Typoscript, so no name is displayed.
Do you have any solution here?
Re: JQAdm Configuration problem in Typo3
Post by aimeos » 26 Aug 2021, 05:45
You can add the new configuration to a PHP config file instead of TypoScript.
We will need to change that in future versions so you can set via TypoScript too.
nvindice
Post by nvindice » 26 Aug 2021, 09:17
Done, setting it via config/admin.php works. Thank you.
However, working with multidimensional arrays would seem a lot cleaner to me. Converting stuff like this to an object will fail, not sure if JSON is fine with an empty string index.
Post by aimeos » 26 Aug 2021, 09:53
Using multi-dimensional arrays with string keys wouldn't return the wished order of the entries any more. We tried to use that before but changed to current implementation afterwards.
nvindice
Post by nvindice » 26 Aug 2021, 11:57
I see. Maybe using index "0" for the title? Or always using the first element in the Array? Not perfect, but IMHO better than the current solution :?
