Aimeos 2021 requires composer 2
loeffe1
Post by loeffe1 » 27 Aug 2021, 08:42
It says in your docs that due to a problem with TYPO3 only composer 1 can be used, however the aimeos composer.json requires composer-runtime-api version 2.1. How does that fit together?
aimeos/aimeos-typo3 2021.07.x-dev requires composer-runtime-api ^2.1 -> no matching package found.
Re: Aimeos 2021 requires composer 2
Post by aimeos » 27 Aug 2021, 14:27
Since 2021.07, composer 2.1+ is required and the documentation has been updated:
https://github.com/aimeos/aimeos-typo3#composer
