[Solved] No bcc mails after upgrade
denzen
Post by denzen » 23 Sep 2021, 10:09
After a TYPO3 upgrade to 10 and an Aimeos upgrade to 21.10, no more bcc mails go out as a copy.
The emails to the customer work and now even have the invoice attached immediately, also with prepayment.
This is the TYPOscript in the scheduler, which worked before the upgrade:
plugin.tx_aimeos.settings.client.html.email.from-name = My Store
plugin.tx_aimeos.settings.client.html.email.from-email = info@mystore.de
plugin.tx_aimeos.settings.client.html.email.reply-name = Bestellung bei Mystore
plugin.tx_aimeos.settings.client.html.email.reply-email = service@mystore.de
plugin.tx_aimeos.settings.client.html.email.bcc-email = support@mystore.de
Does anyone have an idea?
Thank you & Best Regards
Denis
AIMEOS 21.4.2
FreeBSD
PHP 7.4.3
MySQL 5.7.27
TYPO3 10.4.4
denzen
Re: No bcc mails after upgrade
Post by denzen » 23 Sep 2021, 15:48
Another sendmail parameter brought the solution.
This works for me:
/ usr / sbin / sendmail -bs -i -f info@mystore.de
Information is available here:
https://github.com/symfony/symfony/pull/39744
