Problem in Country Dropdown
cnoelker
Post by cnoelker » 02 Nov 2021, 13:19
the country dropdown of the customer maintenance does not work anymore. Message in the browser is:
Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at https://restcountries.eu/rest/v2/all?fi ... 2Code;name. (Reason: CORS request did not succeed).
I tried to open the restcountries.eu site, but this doesn't respond, either.
In https://github.com/aimeos/ai-admin-jqad ... s/admin.js , I see that the method getCountries is marked as @deprecated 2022.01
How can I make this working, again?
Claudia
cnoelker
Re: Problem in Country Dropdown
Post by cnoelker » 02 Nov 2021, 14:23
cnoelker
Post by cnoelker » 02 Nov 2021, 15:22
I changed this in my local code and it fixes the problem.
Post by aimeos » 03 Nov 2021, 07:58
In 2020.10 and later, the problem has been fixed by using a local list of countries instead of asking a REST API for that information.
createanet
Post by createanet » 01 Dec 2021, 06:36
Do you mean 2020.10 and later? Only I cant see the changes that reflect this.
https://github.com/aimeos/ai-admin-jqad ... #L132-L168
Post by aimeos » 01 Dec 2021, 12:45
The JS method is still there for backward compatibility but the country drop-downs are now populated from confiugration:
https://github.com/aimeos/ai-admin-jqad ... #L335-L348
Keep in mind that you need to adapt your own templates if you've overwritten the Aimeos ones.
createanet
Post by createanet » 02 Dec 2021, 15:06
I should have checked the template, thank you :)
