Shop sends orders but doesn't change stock
robert63
Post by robert63 » 03 Nov 2021, 19:24
System is Linux, Typo3 10.4.21, PHP 7.3.30, aimeos 21.10.2
Orders are processed. However, I can order the same product several times even though it should be out of stock, because there was just 1 in stock initially.
robert63
Re: Shop sends orders but doesn't change stock
Post by robert63 » 04 Nov 2021, 14:30
Does nobody else have this issue? It works correct with normal articles, but not with the selections.
An order doesn't reduce the stock.
Post by aimeos » 04 Nov 2021, 18:11
We can confirm that there's a problem with decreasing stock levels for selection products and we will have a look what could be the problem.
Post by aimeos » 08 Nov 2021, 10:54
Problem has been fixed in aimeos/aimeos-core:2021.10.x-dev and will be part of the next release.
robert63
Post by robert63 » 08 Nov 2021, 20:33
Thanks, but I cannot find it in aimeos/aimeos-core:2021.10.x-dev. Is it already available?
Post by aimeos » 09 Nov 2021, 07:45
This is the commit fixing the issue:
https://github.com/aimeos/aimeos-core/c ... 121b852d5e
robert63
Post by robert63 » 09 Nov 2021, 13:39
Works. Thanks.
