local install - external sources
sieg01
Post by sieg01 » 20 Nov 2021, 07:04
Hi @ all.
How can I get Aimeos Distribution running on a local install without external sources?
If I see this right, then it would like to connect to:
aimeos.org
cdn.josdelivr.net
cdnjs.cloudflare.com
In the BE: localhost/aimeos/typo3/module/web/AimeosTxAimeosAdmin
I can only access Log and Dashboard. All other tabs are not accessible.
Is there any adjustment or button like: "local machine without access to internet"?
Thanks!
sieg01
TYPO3 11.5.3
Aimeos_dist 21.10.3
Debian Bookworm
Re: local install - external sources
Post by aimeos » 21 Nov 2021, 14:24
There's no configuration for that. You have to provide an own template for the backend where the used CSS/JS libraries are loaded locally:
https://github.com/aimeos/aimeos-typo3/ ... Jqadm.html
sieg01
Post by sieg01 » 10 Mar 2022, 09:37
Thanks for the fast help! :)
