Wrong link from "suggested products"
I added some products into products/suggested products and also into products/products bought together.
Click (in front end) on a product in both groups link to the home page instead to the concerning product.............?
Thanks!
I work with Typo3 9.5.22 / Aimeos 19.10.4
Thanks!
Re: Wrong link from "suggested products"
Most likely, you did not set up the detail page link correctly in the flexform of the plugin
