Define Filter-Tree-Depth
tomrose
Post by tomrose » 07 Dec 2021, 11:57
I would like to define the tree depth of
client/html/catalog/filter/tree/
so that by default no children will be returned.
Is there a way, like e.g. depth or deep or s.th. like this?
Thanks.
Re: Define Filter-Tree-Depth
Post by aimeos » 07 Dec 2021, 13:01
tomrose
Post by tomrose » 16 Dec 2021, 08:53
Thank you.
In earlier versions, the default behaviour was:
Show main categories only, if no f_catid is given.
In version 2021, the whole tree is shown, not only the main categories.
In the file
/aimeos/ai-client-html/client/html/src/Client/Html/Catalog/Filter/Tree/Standard.php
the lines 257 + 258 read
$catItems = map();
$catIds = [];
I would like to have the old behaviour:
$catItems = $cntl->getTree( \Aimeos\MW\Tree\Manager\Base::LEVEL_ONE )->toList();
$catIds = $catItems->keys()->toArray();
How can I achieve this?
Post by aimeos » 17 Dec 2021, 09:46
Yes, thats because the value for the "Levels always" setting in the flexform of the catalog filter plugin. You should remove the value to get the old behavior.
tomrose
Post by tomrose » 17 Dec 2021, 10:23
Thank you.
I have inserted
    'frontend' => [
        'catalog' => [
            'levels-always' => null,
in the file DistributionPackages/template/Resources/Private/Config/controller.php
The resulting behaviour is:
On the main catalogue-page all subcategories are shown, on a subcategory, only this subcategory is shown.
The second part is okay, but I want the subcategory only on a subcategory, not on the main starting catalogue-page.
