price-item not available after updating
NeulingvonHier
Post by NeulingvonHier » 13 Mar 2015, 08:13
Hi there
after updating yesterday, we are experiencing the following issue:
When adding an item to the basket, it says "Price-item not available.", although it worked before and although there is a price for the product:
As well as a price for the added attributes:
What's interesting is, that in the dropdown list where you see the option for a product(right above the add to basket button), there is no longer a price specified as it was before.
My question: Is this an issue coming with the update or is it our fault somewhere? And how can we fix it?
Thanks for your help.
Re: price-item not available after updating
Post by aimeos » 13 Mar 2015, 09:38
NeulingvonHier wrote: What's interesting is, that in the dropdown list where you see the option for a product(right above the add to basket button), there is no longer a price specified as it was before.
You are using CHF as curreny. Is this the only currency that you have configured in the "Locale" (Gebietschema) tab? If not (and I think you have EUR too), you can change the order of the locales so the one with CHF is first or you can explicitly tell the shop via the
plugin.tx_aimeos.settings.mshop.locale.currency = CHF
TypoScript to use CHF for your current page tree.
Alternatively, you can add the ai[loc_currency]=CHF parameter in your URL so it's dynamic. With Realurl you can make nicer looking URLs like /de/CHF/product/...
You can find the list of available parameters here: http://aimeos.org/docs/Developers/Html_ ... e_selector
NeulingvonHier
Post by NeulingvonHier » 13 Mar 2015, 09:54
Hi!
You guys are awesome.
Haven't had the idea that there is a problem with Locales.
I had German => Euro on Position 2 and German => CHF on Position 0. As I deactivated German => Euro, it worked perfectly fine!
Thanks!
