How to add a Decorator to catalog detail bought-together and suggest subparts
boettner
Post by boettner » 11 Jan 2022, 15:10
Hi all,
I would like to add my Decorator to the catalog detail bought-together and suggest subparts but it seems there's no configuration option to do so.
My goal is price manipulation and it already works in the basket, the checkout and the catalog in general. I also have a Price Rule available but that doesn't affect these subparts either.
Do I have any other chance?
Robert.
Re: How to add a Decorator to catalog detail bought-together and suggest subparts
Post by aimeos » 12 Jan 2022, 08:51
There's no way to add a decorator for that parts in the templates because they are not provided by an own subpart.
The price rules should affect all product prices, regardless where they are used. Unfortunately, this isn't the case for related products yet because only the price of the main product is modified:
https://github.com/aimeos/aimeos-core/b ... hp#L73-L78
Can you create a PR that loops over the referenced products and applies the rules too?
boettner
Post by boettner » 12 Jan 2022, 13:50
Hi and thanks once again for pointing me in the right direction.
Did it like so:
if ( ! ($boughTogetherProducts = $product->getRefItems('product', null, 'bought-together'))->isEmpty()) {
	foreach ($boughTogetherProducts->getRefItems('price') as $price) {
		$taxrate = 19;
		/** @var \Aimeos\MShop\Price\Item\Standard $price */
		$price->setTaxRate($taxrate);
		$price->setValue($price->getValue()->first() * (1 + $taxrate / 100));
$taxrate is of course a dynamic value here. Simplified it for the post.
