Solved -error when it tries to send emails
crazyforester
Post by crazyforester » 04 Feb 2022, 10:15
I have the following :
aimeos 21.10.4
TYPO3 10.4.21
When it is necessary an email to be send for example for Facility
"email/customer/account"
the following error appears
Error while trying to send customer account e-mail: ID parameter needs to be passed for the cHash calculation!
It is the same error and for other actions with email sending
Thanks in advance!
Re: error when it tries to send emails
Post by aimeos » 06 Feb 2022, 10:19
Did you use the "Aimeos advanced scheduler" task and added the page IDs in the required fields?
The standard Aimeos scheduler task without fields for the page IDs isn't suitable for all jobs which send e-mails.
crazyforester
Re: Solved -error when it tries to send emails
Post by crazyforester » 07 Feb 2022, 14:57
that were the problem
The standard Aimeos scheduler doesn't work properly
