Solved -Stripe problem with return_url
crazyforester
I have setup Stripe payment following the manual
https://aimeos.org/docs/latest/manual/services/#stripe
I couldn't find an explanation for the field "type", but I have used the default "Stripe_PaymentIntents"
Stripe gives an error "url_invalid - return_url"
I looked at the log in the Stripe site and error is
"return_url": "//www.mydomain.com/confirm?action=confirm ... r=Checkout"
Thanks in advance
Thanks in advance
crazyforester
Re: Solved -Stripe problem with return_url
The problem were solved by the following TS
plugin.tx_aimeos.settings.client.html.checkout.update.url.config.scheme = https
plugin.tx_aimeos.settings.client.html.checkout.confirm.url.config.scheme = https
