No delivered email and no bcc and deliverd mail not send
Shopmister
Post by Shopmister » 16 Mar 2022, 07:24
1) it send no delivered email (4).
in progess, buyed, new account mail etc. are sending, but the deliverd mail not sent. How i can configure whatss the text of this mail?
i thought in earlier versions the delivered mail was send, but maybe im false :)
2) I have problems with the bcc mail, i tryed in scheduler minute task:
i tryed these
plugin.tx_aimeos.settings.client.html.email.bcc = testemail....
email and other things
And it dont works.
Re: No delivered email and no bcc and deliverd mail not send
Post by aimeos » 18 Mar 2022, 07:30
Shopmister wrote: 16 Mar 2022, 07:24 1) it send no delivered email (4).
Did you add the job for sending the delivery e-mail to the scheduler task?
Shopmister wrote: 16 Mar 2022, 07:24 2) I have problems with the bcc mail, i tryed in scheduler minute task:
i tryed these
This is a bug in the new Symfony Mailer TYPO3 is using and workarounds are described here:
https://github.com/aimeos/aimeos-typo3/issues/164
Shopmister
Post by Shopmister » 19 Mar 2022, 07:27
1)
I didnt understand what to do. I tryed some things like you see from doku here:
Delivery
Delivery e-mails are sent out by the order/email/delivery job after the delivery status of an order has changed. The available order delivery status values are :
STAT_UNFINISHED (-1)
STAT_DELETED (0)
STAT_PENDING (1)
STAT_PROGRESS (2)
STAT_DISPATCHED (3)
STAT_DELIVERED (4)
STAT_LOST (5)
STAT_REFUSED (6)
STAT_RETURNED (7)
For each of these delivery status values you are able to send out an e-mail to the customers informing them about the delivery status change. For which status changes e-mails are sent is configured via the controller/jobs/order/email/delivery/status setting.
2) I dont understand what to do, but how i can use the new Email delivery service provider for dont have to fix from this workaround link?
There's a workaround mentioned: https://forge.typo3.org/issues/92354
Also, you can use the new Email delivery service provider to send order e-mails to shop owners (and adapt the e-mail to your needs).
Post by aimeos » 22 Mar 2022, 08:15
Shopmister wrote: 19 Mar 2022, 07:27
Read here: https://aimeos.org/docs/latest/typo3/setup/#cronjobs
Shopmister wrote: 19 Mar 2022, 07:27 Also, you can use the new Email delivery service provider to send order e-mails to shop owners (and adapt the e-mail to your needs).
Yes
