CSV-Import error Required mapping key "item" is missing or contains no array
maco01
Post by maco01 » 16 Mar 2022, 10:47
I set up a cronjob in Typo3 for the csv import. If I don't specify an individual mapping, the import works without any problems. However, if I use my own mapping, this error always appears:
Execution of task "Aimeos Shop scheduler (aimeos)" failed with the following message: Required mapping key "item" is missing or contains no array.
I use the standard mapping from the documentation in the typoscript configuration field of the scheduler:
controller.common.product.import.csv.mapping = Array (
    [item] => Array
            [0] => product.code
            [1] => product.label
            [2] => product.type
            [3] => product.status
    [text] => Array
            [4] => text.type
            [5] => text.content
            [6] => text.type
            [7] => text.content
    [media] => Array
            [8] => media.url
    [price] => Array
            [9] => price.currencyid
            [10] => price.quantity
            [11] => price.value
            [12] => price.taxrate
    [attribute] => Array
            [13] => attribute.code
            [14] => attribute.type
    [product] => Array
            [15] => product.code
            [16] => product.lists.type
    [property] => Array
            [17] => product.property.value
            [18] => product.property.type
    [catalog] => Array
            [19] => catalog.code
            [20] => catalog.lists.type
Does anyone have any advice as to what the error is?
Thanks & regards!
Re: CSV-Import error Required mapping key "item" is missing or contains no array
Post by aimeos » 18 Mar 2022, 07:56
This is not valid TypoScript:
Don't mix PHP examples from the docs with TypoScript configuration from TYPO3. A valid mapping in TypoScript would be:
controller.common.product.import.csv.mapping {
    item {
        0 = product.code
        1 = product.label
        2 = product.type
        3 = product.status
    # more mappings
maco01
Post by maco01 » 04 Apr 2022, 11:11
Thank you for your answear - it works now.
