Trailing Slash for Product URL
didev
Post by didev » 15 May 2022, 11:13
I would like to set a trailing slash to the product-urls. My config.yaml looks like this
- { routePath: '/{d_prodid}-{d_pos}-{d_name}', _controller: 'Catalog::detail' }
I tried the solution for Problems with routeEnhancers and Slash PageTypeSuffix but it didn't worked.
Also played around with something like this
- { routePath: '/{d_prodid}-{d_pos}-{d_name}/', _controller: 'Catalog::detail' }
and
    default: /
    suffix: /
    index: /
    map:
      /: 0
      stock: 191351524
Also tried with
return $this->view->url($detailTarget, $detailController, $detailAction, $params, ['d_name' => '/'], $detailConfig);
but didn't worked either.
Do you have any suggestions whats maybe wrong with my config?
Typo3: 11.5.9
Aimeos: 21.10.5
Thanks a lot!
Regards
David
Re: Trailing Slash for Product URL
Post by aimeos » 16 May 2022, 06:42
That's a TYPO3 specific question you should better ask in a TYPO3 related forum.
didev
Post by didev » 17 May 2022, 09:29
Hey thanks for your reply,
but I think it's not a TYPO3-related issue. Because if I add a "/" to the product URL I get the error message:
Item with ID "/" in "product.id" not found. So I think Aimeos checks the url after the last slash?!
If I add some other characters like "+" or "=" the url ends with that characters.
/p/123-name+ -> no problem
/p/123-name= -> no problem
/p/123-name/ -> doesnt work
If I use Aimeos\MW\View ->url(.., $trailing,...) and I add ->url(..., ['/'],...) the url looks like this
/p/123-name#/ -> no problem
why I cant use the ->url() method without the '#' char?
Regards
David
Post by aimeos » 18 May 2022, 06:24
Your configured route path is "/{d_prodid}-{d_pos}-{d_name}/". Thus, you need URLs like "/p/123-0-name/" and "/p/123-name/" can't be resolved correctly by TYPO3 (because the d_pos parameter is missing).
