Set Catalog attribute plugin to OR
billy678
Post by billy678 » 02 Jun 2022, 16:14
is there an option to set the catalog attribute plugin to OR?
Thank you & best regards!
Re: Set Catalog attribute plugin to OR
Post by aimeos » 03 Jun 2022, 05:22
Use this configuration for the attribute types you want to use OR conditions for:
https://aimeos.org/docs/2022.x/config/c ... ypes-oneof
billy678
Post by billy678 » 03 Jun 2022, 09:43
That works - thank you!
If someone is trying it too:
I added this to the TS-Config box in the plugin
client.html.catalog.filter.attribute.types-oneof.1 = category
