Default theme overrides basic elements
Moritz
Post by Moritz » 20 Sep 2022, 13:38
The default elegance theme overrides very basic elements like header, body, footer, img or a.
Also bootstrap classes like .navbar are overridden.
This destroys the frontend styles of my sitepackage.
Is that the expected behaviour?
I think every style rule should start with the aimeos root class (.aimeos ...).
Maybe there is already a solution for that?
Thanks in advance!
PHP 8.2.24
Typo3 v12.4.23 LTS
Aimeos web shop 24.10.2
Re: Default theme overrides basic elements
Post by aimeos » 21 Sep 2022, 07:05
Create your own theme using a copy of the CSS/JS files from the default theme. Then, remove all header and footer styles from the aimeos.css file so they don't interfere with yours.
Moritz
Post by Moritz » 21 Sep 2022, 13:05
With Typo3 it only works if I set the path to my custom CSS via TypoScript?
How it works with all the CSS files which are included for specific components (like catalog-lists.css)?
And how do you prefer migrate old templates and styles from v18 to v22?
Is there a way to keep the old ones and use the old elegance theme?
Or is it better to start from scratch?
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 22 Sep 2022, 15:15
Moritz wrote: 21 Sep 2022, 13:05 With Typo3 it only works if I set the path to my custom CSS via TypoScript?
In Aimeos 2022.x, there's a virtual file system defined for the theme files:
https://github.com/aimeos/aimeos-typo3/ ... hp#L40-L45
Moritz wrote: 21 Sep 2022, 13:05 And how do you prefer migrate old templates and styles from v18 to v22?
From a technical perspective, it's better to start from scratch resp. use the new CSS/JS files from the theme and add your custom code in your own CSS/JS file because the Aimeos frontend is now optimized for very fast page loading and top Google Lighthouse scores for best user experience.
Moritz
Post by Moritz » 23 Sep 2022, 06:56
How can I configure the theme path that it takes the .css & .js files of my extension?
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 24 Sep 2022, 06:17
Use:
plugin.tx_aimeos.settings.resource.fs-theme.baseurl = /url/path/to/directory
plugin.tx_aimeos.settings.resource.fs-theme.basedir = /absolute/path/to/directory
Moritz
Post by Moritz » 26 Sep 2022, 07:47
I found another way to archive this.
In my extension I create this file "typo3conf/ext/my_ext/Resources/Private/Config/resource.php".
There I can override the settings aswell.
Thank you very much for support!
PHP 8.2.24
Typo3 v12.4.23 LTS
