Disable meta tags for google structured data
maco01
Post by maco01 » 21 Sep 2022, 07:11
is it possible to disable the following meta tags?
<meta property="product:price:amount" content="99.00">
<meta property="product:price:currency" content="EUR">
We are using aimeos as an online catalog without prices and google reads the above meta tags for the structured data view in the google search. In our case we have to disable this meta tags.
Any tipp how we can do this?
Thanks and regards!
Re: Disable meta tags for google structured data
Post by aimeos » 21 Sep 2022, 12:26
You can copy the templates and remove the meta tags.
