ckeditor headings
rvhelp2
ckeditor headings
Post by rvhelp2 » 16 Nov 2022, 17:23
I tried to enable headings in the ckeditor.
Aimeos.ckeditor.toolbar = [
    'heading', '|',
The "heading" entry has no effect. Do I have to install something additional first?
Re: ckeditor headings
Post by aimeos » 17 Nov 2022, 18:42
The "Heading" plugin is part of the CKEditor source shipped with Aimeos:
https://raw.githubusercontent.com/aimeo ... keditor.js
It works pretty well if you place the code into the EXT:<yourext>/Resources/Private/Extensions/<yourext>/themes/admin/jqadm/custom.js file of your own Aimeos extension (Aimeos 2022.10 example):
    'heading', '|',
    'link', '|',
    'bold', 'italic', '|',
    'undo', 'redo', '|',
    'specialCharacters', 'removeFormat', '|',
    'bulletedList', 'numberedList', '|',
    'blockQuote', '|',
    'insertTable', 'mediaEmbed', '|',
    'sourceEditing'
rvhelp2
Post by rvhelp2 » 18 Nov 2022, 09:40
I tried, but in our case "heading" has no effect. I could add or remove other elements:
Post by aimeos » 19 Nov 2022, 08:12
Which Aimeos version do you use? Maybe the "Heading" plugin isn't available in that version. The example was for 2022.10 LTS.
rvhelp2
Post by rvhelp2 » 25 Nov 2022, 09:46
i replaced CKEditor.js and components/html-editor.js in 22.4 with 22.10. Now it workes. Thanks
