Custom Plugin Configuration
gurubroz
Post by gurubroz » 08 Dec 2022, 10:08
Hey there!
Greetings!
TYPO3 version: 11.5.16
Aimeos version: 22.7.2
I have configured the new custom plugin as per https://aimeos.org/docs/2021.x/provider ... ugins/this documentation.
My Aimeos version is 2022.10.X. But in the backend Administrative module, I can't find the plugin.
What am I missing? Help is appreciated.
Thanks!
Re: Custom Plugin Configuration
Post by aimeos » 08 Dec 2022, 10:16
You've used the wrong version (2021.x vs. 2022.x) and the location has changed:
https://aimeos.org/docs/latest/provider ... t-plugins/
gurubroz
Post by gurubroz » 08 Dec 2022, 10:21
Yes, but the documentation is the same for both versions :)
Not a single word changes, even screenshot also the same, it should be new interface screenshot there like https://i.imgur.com/j0NQpL5.png
Post by aimeos » 08 Dec 2022, 10:22
The file location in your extension has changed.
gurubroz
Post by gurubroz » 08 Dec 2022, 10:25
which is correct?
I have created a class into - https://i.imgur.com/BCFChya.png
Is it not correct?
Post by aimeos » 08 Dec 2022, 10:28
No, it's:
./<yourext>/Resources/Private/Extensions/<yourext>/src/MShop/Plugin/Provider/Order/ExamplePlugin.php
gurubroz
Post by gurubroz » 08 Dec 2022, 10:32
Based on this configuration https://i.imgur.com/KcQ7nPx.png
$GLOBALS['TYPO3_CONF_VARS']['EXTCONF']['aimeos']['extDirs']['1_aimeos'] =
	'EXT:theme_pros/Resources/Private/Extensions/';
$GLOBALS['TYPO3_CONF_VARS']['EXTCONF']['aimeos']['confDirs']['1_aimeos'] =
	'EXT:theme_pros/Resources/Private/Extensions/aimeos/config/';
My path is correct I guess, JFYI. Templating override is working fine.
