Copy product - Download file deleted
Moritz
Post by Moritz » 09 Dec 2022, 14:18
If I copy a product with a download file and remove the copied product, the file is also deleted from the original.
PHP 8.2.24
Typo3 v12.4.23 LTS
Aimeos web shop 24.10.2
Re: Copy product - Download file deleted
Post by aimeos » 09 Dec 2022, 14:36
They both refer to the same attribute that stores the relative file name of the download file.
The only options to avoid that would be to copy the attribute and the file too (can lead to ghost files if the product isn't saved after copying) or remove the download attribute when copying the product.
Post by aimeos » 19 Dec 2022, 13:35
We've decided to remove the download attribute from the copied product now. The change will be available with the next release or if you use:
composer req aimeos/ai-admin-jqadm:2022.10.x.dev
Moritz
Post by Moritz » 19 Dec 2022, 13:37
This is a good compromise. Thank you for the implementation.
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 21 Dec 2022, 13:47
New version including the change has been released today.
Moritz
Post by Moritz » 21 Dec 2022, 13:53
Ok, I will test it maybe this week or after holiday in the next year.
Thank you very much for your support the last months and happy christmas! 🙂
PHP 8.2.24
Typo3 v12.4.23 LTS
