Account profile
Account profile
hello,
if the user is logged in, on an account tab it should show the current data of the logged in user.
It says success, you're now logged in as 'user@email.com' and technically, as soon as you click on the account page again, it should come up with the account profile overview, but instead you're greeted with the login again.
In backend, on the account page the account profile is marked at "show at any login". Any fix?
And when clicking on the password reset button, we're prompted with "Oops, an error occurred! Code: 202301301248278b714176"
Best Regards
Best Regards
Re: Account profile
Seems like the session is lost somehow.Joseph wrote: 30 Jan 2023, 12:49 if the user is logged in, on an account tab it should show the current data of the logged in user.
Check the log file in ./var/logs/ for the error.Joseph wrote: 30 Jan 2023, 12:49 And when clicking on the password reset button, we're prompted with "Oops, an error occurred! Code: 202301301248278b714176"
