XML Importer / TYPO3 / attributes and categories won't update and throwing errors
kai_lf
Post by kai_lf » 10 Mar 2023, 08:54
I am in the process of implementing the XML importer for categories, products and attributes in our shop. Initially, all three XML work really well. Only when I want to import the attributes or the categories a second time I get error messages "... Integrity constraint violation: 1062 Duplicate entry ...".
With the products it works fine. If I delete the categories or attributes in the shop and import them, everything is fine.
Is it possible that an update of the categories and attributes does not work - or what am I doing wrong? Is there anything else I can configure?
I am using aimeos V22.10.5 / TYPO3 11.5.24
Re: XML Importer / TYPO3 / attributes and categories won't update and throwing errors
Post by aimeos » 13 Mar 2023, 16:23
The "ref" attribute in the XML nodes must contain the unique key that is required match existing records, e.g.:
<attributeitem ref="product|color|black"
It contains record domain, type and value for attributes.
kai_lf
Post by kai_lf » 14 Mar 2023, 12:31
Yess. Thanx! I had some UTF8 encoding Problems. For all having similar problems...
If you are using PHP and simpleXML -> initialize your XML like:
$this->productsxml = new SimpleXMLElement('<?xml version="1.0" encoding="UTF-8"?><attributes/>');
Output:
<attributeitem ref="product|Größe|M">
    <attribute.domain><![CDATA[product]]></attribute.domain>
    <attribute.type><![CDATA[Größe]]></attribute.type>
    <attribute.code><![CDATA[M]]></attribute.code>
    <attribute.label><![CDATA[Größe-M]]></attribute.label>
  </attributeitem>
I had:
$this->productsxml = new SimpleXMLElement('<attributes/>');
Output:
 <attributeitem ref="product|Gr&#xF6;&#xDF;e|M">
  </attributeitem>
which generates a valid XML, but was not importable to aimeos, because of "Gr&#xF6;&#xDF;e" = Größe.
