Get the Category Position from Product
rvhelp2
Post by rvhelp2 » 14 Mar 2023, 18:09
I am searching for certain products by attribute. From these products I need the position in the respective category. I understand that a product has several categories and each its own position. Is there a way how I can include a category to get the positions via JSON API?
/shop/json-api?ai[resource]=product&ai[include]=product,attribute,price,label,media,text&ai[sort]=relevance
Re: Get the Category Position from Product
Post by aimeos » 15 Mar 2023, 21:29
Add "catalog" to the "include" parameter. Then, you get the categories these products are attached too and the "relationships/catalog/data" sections contain the "product.lists.position" attribution with the position of the product within that category.
rvhelp2
Post by rvhelp2 » 24 Mar 2023, 10:25
Thx! It is also possible to add the category filter to the attribut filter (if all products with the attribut are in the same category). then it will be auto sorted by relevance/ category index.
Post by aimeos » 27 Mar 2023, 17:11
Not sure if I understand correctly what you want to achieve. Can you describe in more detail, please?
