Use sub-shop
mrenevey
Use sub-shop
Post by mrenevey » 17 Nov 2015, 11:07
First, thank you for your great extension 8-) . All functions cover my needs, but I have to know one last thing .
How to configure sub-shops ? Here you say that you have an extension wich enables to add sub-shops : https://aimeos.org/docs/User_Manual/Adm ... with_sites
But I've checked documentation and found nothing how to do that (install extension, configure Aimeos).
I have other questions about how work sub-shops :
- Is it possible to have a master Shop with all products/categories, and to choose in subshops wich products/categories are displayed ?
- Is it possible to have a master Shop with products, and to choose in subshop a different image for this product ?
- I must detect the market with my own code (IP or maybe browser configuration). After that, is it possible to display / activate one sub-shop only ?
Thank you for your help
Mathieu
Re: Use sub-shop
Post by aimeos » 17 Nov 2015, 22:56
mrenevey wrote: How to configure sub-shops ? Here you say that you have an extension wich enables to add sub-shops : https://aimeos.org/docs/User_Manual/Adm ... with_sites
I know that there is something like this and I've forwarded your request so the developers can get in touch with you.
mrenevey wrote: I have other questions about how work sub-shops :
Not sure about the last one but the rest should be possible (IIRC).
jeroenk
Re: Use sub-shop
Post by jeroenk » 02 Mar 2017, 12:27
Hi, This is exactly where we are looking for as well.
"Furthermore, the we also offer an extension which enables you to add sub-shops that inherit products, categories, pictures, texts, etc. from a parent instance and you can even add more sites to these sub-shops without any restrictions in depth. This is perfect for market places or resellers. "
But we can't find more about it. Do you have more information to send us?
Jeroen
Re: Use sub-shop
Post by aimeos » 02 Mar 2017, 15:04
The features are available when using an extension (Market places and complex B2B requirements) offered by the Aimeos company: https://aimeos.com/extensions/
For more information and a full feature list, please contact them directly:
https://aimeos.com/aimeos-gmbh/contact/
