Request fot coupon not working
heural
Post by heural » 25 Apr 2023, 08:36
Hi Aimeos-Team,
if I request a coupon code in the basket, the called url in the xhr-Request is http://maydomain/undefined
The code in basket-standard.js makes no sense for me: what is product.data("url")?
onSubmit() {
                $(document).on("submit", ".basket-standard form", ev => {
                        Aimeos.createSpinner();
                        fetch(product.data("url"), {
                                body: new FormData(ev.currentTarget),
                                method: 'POST'
                        }).then(response => {
                                return response.text();
                        }).then(data => {
                                $(".basket-standard").html(AimeosBasket.updateBasket(data).html());
                        }).finally(() => {
                                Aimeos.removeSpinner();
                        return false;
If I changed to "ev.currentTarget.form.action" the form works...
Thank you!
Thanks a lot!
Re: Request fot coupon not working
Post by aimeos » 26 Apr 2023, 06:54
You mean this line?
Using "ev.currentTarget.form.action" seems to be wrong too but "ev.currentTarget.form" may be correct.
heural
Post by heural » 03 May 2023, 11:56
No, I mean
there is no "product" object present.
So if i change to
 fetch(ev.currentTarget.form.action, {
the request works.
Thanks a lot!
Post by aimeos » 07 May 2023, 11:02
You are right, that doesn't make any sense but your suggested code doesn't work either in all situations. Instead, we are now using this line, which seem to work perfectly:
fetch($(ev.currentTarget).attr("action"), {
The updated code is available in aimeos/ai-client-html:2022.10.x-dev. Can you check if it now works for you too?
