Filter by categories
loeffe1
Post by loeffe1 » 26 Apr 2023, 08:48
Is it possible to add a category filter? The requirement is to be able to select multiple categories through the filter and display products from these selected categories. It should work combined with other filters aswell, so it shoud be possible to filter by multiple categories and price for example.
Re: Filter by categories
Post by aimeos » 29 Apr 2023, 07:29
Yes, you have to overwrite the catalog/filter/tree templates and use checkboxes instead of links. The catalog/lists HTML client can use array of category IDs too:
https://github.com/aimeos/ai-client-htm ... d.php#L360
loeffe1
Post by loeffe1 » 02 May 2023, 14:30
This is great, thanks!
