Strange behavior when replacing AimeosPage.onHideOffscreen
loeffe1
Post by loeffe1 » 05 May 2023, 07:54
If I replace this function within $(function() { } in my custom js, it is not executed at all. If I replace it not nested, it is executed twice. Why is this happening?
AimeosPage.onHideOffscreen = function() {
  $('.aimeos-overlay-offscreen').on('click', () => {
    console.log("click")
    $('.aimeos-overlay-offscreen').removeClass('show');
    $('.zeynep.opened').removeClass('opened');
click will not be logged if this block is nested within $(function() { } and will be logged twice if not nested
Re: Strange behavior when replacing AimeosPage.onHideOffscreen
Post by aimeos » 07 May 2023, 11:53
loeffe1 wrote: 05 May 2023, 07:54
The code seems to be correct. Is your custom.js file included after the aimeos.js file?
loeffe1
Post by loeffe1 » 09 May 2023, 10:01
Yes it is.
