extended search
ReturnOfJoseph
extended search
Post by ReturnOfJoseph » 17 May 2023, 08:35
currently, it's possible to find products by entering the full SKU in the search bar. Is there an option to allow an extended search, so that you can enter just a part of the SKU, and it suggests a few products, or one/none, that include the entered part of the SKU?
Best regards
Re: extended search
Post by aimeos » 18 May 2023, 07:39
The SKU is stored as text in the full text index of the product and will be found if you enter it into the search bar of the catalog filter plugin. The full text index uses a prefix search, so only SKUs are found that start with the same characters (at least three) but not parts of the SKU which are in the middle or the end of the SKU.
