Add VAT in basket, not on product pages
AndyH
Post by AndyH » 30 Nov 2015, 14:38
Hello aimeos team,
I'm creating an B2B shop where the prices on product detail pages should be shown without Value Added Taxes (which is common in B2B).
The current hint "Incl. 19% VAT" should be replaced by "plus VAT". I assume this can be done by overriding the client/html templates.
Where I have no idea how to start is how should the VAT be added to the Sub-total in the basket. Is there allready a configuration available in aimeos or is there a best practice?
Thank you again for your help!
Best wishes
Andreas
Re: Add VAT in basket, not on product pages
Post by aimeos » 30 Nov 2015, 15:14
AndyH wrote:The current hint "Incl. 19% VAT" should be replaced by "plus VAT". I assume this can be done by overriding the client/html templates.
It's much easier! This string is part of the translation and you can change it by overwriting it in TypoScript:
https://aimeos.org/docs/TYPO3/Overwrite_translations
The translation domain is "client/html" and the string is "Incl. %1$s%% VAT" (https://github.com/aimeos/aimeos-core/b ... lt.php#L26)
AndyH
Post by AndyH » 30 Nov 2015, 15:55
This works like a charm.
Do you have also a tip for me how to do the calculation in the basket?
Post by aimeos » 30 Nov 2015, 17:10
AndyH wrote:Do you have also a tip for me how to do the calculation in the basket?
Unfortunately, that's not as easy as the previous question.
The good thing is the tax calculation is done only in one place:
https://github.com/aimeos/aimeos-core/b ... efault.php
But the main problem is the payment. In your own country, your customer has to pay the price including VAT even for B2B, customers from other countries don't. There's no single solution that handles all variations (incl. mixed B2B+B2C) perfectly yet.
AndyH
Post by AndyH » 01 Dec 2015, 16:47
Thanks for the hint. This seems to work.
marksyl
Post by marksyl » 05 Dec 2015, 10:42
hi!
this way:?
 plugin.tx_aimeos.settings.i18n.en.0 {
      domain = client/html
      string = taxrate
      trans =Incl.  VAT
lg thanx marksyl
Post by aimeos » 05 Dec 2015, 11:40
      string = taxrate
      trans =Incl.  VAT
No, the string needs to be the original value "Incl. %1$s%% VAT":
    string = Incl. %1$s%% VAT
    trans = plus VAT
marksyl
Post by marksyl » 05 Dec 2015, 13:00
thank you very much, it works!
