Aimeos web shop distribution in typo3
jk1234
Post by jk1234 » 26 Jun 2023, 09:24
Hi, I started the process of implementing distribution but some of the required SQL tables are missing. Typo3 version is 11.5.28 and I tried it on PHP versions 7.4 and 8.1.
Re: Aimeos web shop distribution in typo3
Post by aimeos » 27 Jun 2023, 08:25
Did you install the distribution from the extension manager?
Maybe something went wrong (e.g. PHP execution time limit) and the table haven't been created. You can try to run the TYPO3 Upgrade Wizards again from the TYPO3 backend.
jk1234
Post by jk1234 » 28 Jun 2023, 08:54
I did thanks for advice it works now!
