JsonAPI bulk order autosuggest request leads to 404
boettner
Post by boettner » 20 Jul 2023, 14:05
Hi all,
on TYPO 11.5.29 and Aimeos 22.10.7 the following GET request leads to a 404 when trying to add a product via the bulk order form
https://dev.domain.com/jsonapi?ai[actio ... &ai[filter][||][0][=~][product.code]=99000009580&ai[filter][||][1][%3E][index.text:relevance(%22en%22,%2299000009580%22)]=0&ai[include]=attribute,text,price,product
Whereas the https://dev.domain.com/jsonapi?ai%5Bcontroller%5D=Url OPTIONS request for retrieving the resources works. So the basic routing configuration should be ok.
I will be able to upgrade to 23.7 in the near future but maybe I can backport something in case this should be a bug.
Best
Robert.
Re: JsonAPI bulk order autosuggest request leads to 404
Post by aimeos » 21 Jul 2023, 10:14
There seems to be a problem in TYPO3 setups only. In the Laravel demo it's working, in the TYPO3 demo not.
According to the JS error in the browser console, there's no valid JSON:API URL available for the (product) resource but the only difference seems to be that in TYPO3 the domain is missing in the OPTIONS response:
TYPO3 JSON:API OPTIONS response:
product: "/jsonapi?ai%5Baction%5D=options&ai%5Bcontroller%5D=Jsonapi&ai%5Bresource%5D=product"
Laravel JSON:API OPTIONS response:
product: "https://laravel.demo.aimeos.org/jsonapi/product"
boettner
Post by boettner » 21 Jul 2023, 13:15
At least in my setup the OPTIONS request returns an absolute URL scheme:
"resources": {"attribute":"https:\/\/dev.domain.com\/jsonapi?ai%5Baction%5D=options&ai%5Bcontroller%5D=Jsonapi&ai%5Bresource%5D=attribute",
"basket":"https:\/\/dev.domain.com\/jsonapi?ai%5Baction%5D=options&ai%5Bcontroller%5D=Jsonapi&ai%5Bresource%5D=basket",
"catalog":"https:\/\/dev.domain.com\/jsonapi?ai%5Baction%5D=options&ai%5Bcontroller%5D=Jsonapi&ai%5Bresource%5D=catalog",
"customer":"https:\/\/dev.domain.com\/jsonapi?ai%5Baction%5D=options&ai%5Bcontroller%5D=Jsonapi&ai%5Bresource%5D=customer",
"locale":"https:\/\/dev.domain.com\/jsonapi?ai%5Baction%5D=options&ai%5Bcontroller%5D=Jsonapi&ai%5Bresource%5D=locale",
"order":"https:\/\/dev.domain.com\/jsonapi?ai%5Baction%5D=options&ai%5Bcontroller%5D=Jsonapi&ai%5Bresource%5D=order",
"product":"https:\/\/dev.domain.com\/jsonapi?ai%5Baction%5D=options&ai%5Bcontroller%5D=Jsonapi&ai%5Bresource%5D=product",
"review":"https:\/\/dev.domain.com\/jsonapi?ai%5Baction%5D=options&ai%5Bcontroller%5D=Jsonapi&ai%5Bresource%5D=review",
"site":"https:\/\/dev.domain.com\/jsonapi?ai%5Baction%5D=options&ai%5Bcontroller%5D=Jsonapi&ai%5Bresource%5D=site",
"service":"https:\/\/dev.domain.com\/jsonapi?ai%5Baction%5D=options&ai%5Bcontroller%5D=Jsonapi&ai%5Bresource%5D=service",
"stock":"https:\/\/dev.domain.com\/jsonapi?ai%5Baction%5D=options&ai%5Bcontroller%5D=Jsonapi&ai%5Bresource%5D=stock",
"supplier":"https:\/\/dev.domain.com\/jsonapi?ai%5Baction%5D=options&ai%5Bcontroller%5D=Jsonapi&ai%5Bresource%5D=supplier"}
boettner
Post by boettner » 23 Jul 2023, 09:47
A follow up to my quick reply from Friday. I guess it‘s more like TYPO3 classifying it as not routable then. My first guess for a reason would be the nested GET array. I will try to debug that further to find the root cause.
Changing the nested filter array to a single query string might be a solution. Am I right in the assumption that this is all client side anyway?
boettner
Post by boettner » 24 Jul 2023, 13:43
Simple solution for all cases in which it does not impose any security risks is setting
$GLOBALS['TYPO3_CONF_VARS']['FE']['pageNotFoundOnCHashError']
to false.
For other cases one has to deal with TYPO3 routing and define some kind of exclusion or special treatment for the ai[filter] maybe via a PSR-15 request Middleware.
