How to keep categories tree expanded?
Another issue that I'm struggling for is how to keep categories tree (in the catalog filter) expanded when the site is being loaded?
Best regards,
Dominik
Best regards,
Dominik
Re: How to keep categories tree expanded?
You need to overwrite the Javascript function for the catalog filter tree in the theme (aimeos.js). The setupCategoryToggle() is one of the method of the AimeosCatalogFilter object which you have to overwrite:abcdomino wrote:Another issue that I'm struggling for is how to keep categories tree (in the catalog filter) expanded when the site is being loaded?
https://aimeos.org/docs/Developers/Them ... Javascript
Thanks a lot, I will be trying...
Best Regards,
Dominik
Best Regards,
Dominik
Use CSS to show the menu initially:
Optionally hide the Categories header:
.catalog-filter-tree > ul {
display: block;
}Code: Select all
.catalog-filter-tree > h2 {
display: none;
