All subscriptions end at 00:00
Jens3456
Post by Jens3456 » 29 Sep 2023, 04:42
I tried different subscriptions (1h, 24h).
When I examine the start, renew and end times of these subscriptions in the customer account plugin, I notice that only the "Created" entry has the correct date and time.
The Renew entry points to the correct date but 00:00. This means that a 1-hour subscription that was created at 21:15. will not be renewed or ended until 00:00.
A 24-hour subscription only occurs at the end of the following day.
Is it possible to use the subscriptions on an hourly basis? In the code, the times are processed correctly in the format (Y-m-d H:i:s), but at the end it is always Y-m-d 00:00.
Used versions: Typo3 12, Aimeos 2023 and PHP 8.1.
Many thanks
Re: All subscriptions end at 00:00
Post by aimeos » 29 Sep 2023, 07:08
Now, hours/minutes/seconds will be used when renewing subscriptions:
https://github.com/aimeos/ai-controller ... b8957c480a
The change will be part of the next release or you can use it by executing:
composer req aimeos/ai-controller-jobs:2023.07.x-dev
