Overwriting the email templates?
Webrocker
Post by Webrocker » 05 Dec 2023, 18:30
I'm using TYPO3 v11.5.27 and aimeos v22.10.9, PHP 8.1 on Ubuntu
I'm a bit confused how and where the templates for the emails that get send via the cronjob can be overwritten.
I have spent quite some time now in the aimeos docs, but I think I'm too thickheaded to understand how this is supposed to work :-)
I see that in
typo3conf/ext/aimeos/Resources/Private/Libraries/aimeos/ai-controller-jobs/templates/order/email
there are the templates that I need to modify.
I have a extension in
typo3conf/ext/my_shop/
where, aside from the TYPO3 stuff, there is a
typo3conf/ext/my_shop/Resources/Private/Extensions/aimeos/
directory which contains the stuff that a "aimeos" extension (not the aimeos TYPO3 extension) has. Config, Setup, etc and a Template directory.
In that Template directory I can add modifications, for example for the price partial:
typo3conf/ext/my_shop/templates/client/html/common/partials/price.php
This works, and I see the changes in the front end.
Now if I try to overwrite the above mentioned controller-jobs templates
typo3conf/ext/my_shop/templates/controller/jobs/order/email/html.php
This doesn't work. If I set this template file via the TypoScript settings directly at the cronjob setup, it only works if I give the absolute path there -- like
controller.jobs.order.email.payment.template-html = /var/www/htdocs/typo3conf/ext/my_shop/....../html.php
I think this is a problem then if this template uses partials?
What if I need to modify the partial for the email-oder-Summary only?
It would be cool if someone could shed some light how these overrides are supposed to work. The Aimeos shop is already a config beast, and having it inside another config beast like TYPO3, is, wow. This is way over my head currently, it seems :-))
Sorry if this is a n00b question that has been answered already before, I gladly take any RTFM links.
Many thanks,
Tom
Re: Overwriting the email templates?
Post by aimeos » 06 Dec 2023, 12:44
Webrocker wrote: 05 Dec 2023, 18:30 I have a extension in
That shouldn't work because the directory is (replace "<ext>" with your extension name):
typo3conf/ext/<ext>/Resources/Private/Extensions/<ext>/templates/client/html/common/partials/price.php
Webrocker wrote: 05 Dec 2023, 18:30 Now if I try to overwrite the above mentioned controller-jobs templates
This is the correct path for your file:
typo3conf/ext/<ext>/Resources/Private/Extensions/<ext>/templates/controller/jobs/order/email/html.php
Webrocker wrote: 05 Dec 2023, 18:30 If I set this template file via the TypoScript settings directly at the cronjob setup, it only works if I give the absolute path there -- like
By default, the template paths are relative to the ./template/ directories (specified in the typo3conf/ext/<ext>/Resources/Private/Extensions/<ext>/manifest.php file). Absolute paths work too for single files if they are not in the ./template/ directories.
Webrocker wrote: 05 Dec 2023, 18:30 I think this is a problem then if this template uses partials?
Just place the partial in the same sub-directory of the ./templates/ directory in your extension as it is in the Aimeos ai-client-html extension.
Webrocker
Post by Webrocker » 06 Dec 2023, 12:55
thanks for the fast answer!
you're right, but I typed the wrong path in my post. my path is
typo3conf/ext/my_shop/Resources/Private/Extensions/aimeos/templates/client/html/common/partials/price.php
But interestingly, it does work currently even if the "second" <ext> part is not "my_shop" (my exts name), but "aimeos"
(I tried that thinking, maybe it needs the name of the typo3 extension that it is overwriting, it was "my_shop" initially).
Ok but anyways, thanks for the infos, really appreciated.
I think we overlooked the manifest.php role.
A follow-up question - are the .mjml files compiled to .php automagically, or do I need to compile them if I would need to make fundamental (html) markup changes for the template?
thx,
Tom
Post by aimeos » 08 Dec 2023, 09:06
Webrocker wrote: 06 Dec 2023, 12:55 But interestingly, it does work currently even if the "second" <ext> part is not "my_shop" (my exts name), but "aimeos"
The name of the second directory is not relevant because all directories in the ./Resources/Private/Extensions/ directory are scanned and included automatically.
Webrocker wrote: 06 Dec 2023, 12:55 A follow-up question - are the .mjml files compiled to .php automagically, or do I need to compile them if I would need to make fundamental (html) markup changes for the template?
They need to be translated manually and we use VSCode for that because there's an extension for MJML files available.
