Custom order in product manager
loeffe1
Post by loeffe1 » 16 Jan 2024, 14:16
I am fetching products by a comma separated list of product codes. When passing this list to the product manager, the order is lost and instead the products are ordered by product id. How can I ensure the order of my list is respected?
This is the relevant code in my Decorator:
$codesArray = explode(',', $codes);
        $manager = \Aimeos\MShop::create($context, 'product');
        $search = $manager->filter()->add( ['product.code' => $codesArray] )->slice( 0, count( $codesArray ) );
        $result = $manager->search( $search );
        $cntl = \Aimeos\Controller\Frontend::create($context, 'product');
        return $cntl
            ->uses($domains)
            ->product($result->keys()->toArray())
            ->search();
Re: Custom order in product manager
Post by aimeos » 18 Jan 2024, 15:13
You have to sort the result set using the PHP Map "uasort()" method before returning the result:
https://php-map.org/#uasort
