Invoice Email PDF file name
Webrocker
Post by Webrocker » 22 Jan 2024, 11:41
is there an option to alter the filename of the PDF that gets attached to the order/payment email when the option "pdf = 1" is set ("invoice-123.pdf")?
thanks again,
Tom
Webrocker
Re: Invoice Email PDF file name
Post by Webrocker » 22 Jan 2024, 20:15
I found this:
https://github.com/aimeos/ai-controller ... 3C2-L303C1
	protected function filename( \Aimeos\MShop\Order\Item\Iface $order ) : string
		return $this->context()->translate( 'controller/jobs', 'Invoice' ) . '-' . $order->getInvoiceNumber() . '.pdf';
since here the filename is hard coded, it doesn't look like it is supposed to be changed via config
Post by aimeos » 23 Jan 2024, 08:00
Not via configuration but you can overwrite it in the ext_localconf.php of your own project-specific Aimeos extension like this:
\Aimeos\Controller\Jobs\Order\Email\Payment\Standard::macro( 'filename', function( \Aimeos\MShop\Order\Item\Iface $order ) {
	return 'Bestellung-' . $order->getId() . '_' . $order->getTimeCreated() . '.pdf';
Webrocker
Post by Webrocker » 24 Jan 2024, 17:55
Can confirm this works fine! Thank you. :-)
