Error after Installation in TYPO3 12LTS / aimeos-typo3 23.10
taunusweb
Post by taunusweb » 23 Feb 2024, 09:33
Hi there,
I try to install aimeos in a ddev Project (PHP 8.3, TYPO3 12.4.11, aimeos-typo3 23.10.3), but I get the following Error:
Fatal error: Declaration of Aimeos\Aimeos\Command\JobsCommand::execute(Symfony\Component\Console\Input\InputInterface $input, Symfony\Component\Console\Output\OutputInterface $output) must be compatible with Symfony\Component\Console\Command\Command::execute(Symfony\Component\Console\Input\InputInterface $input, Symfony\Component\Console\Output\OutputInterface $output): int in /var/www/html/vendor/aimeos/aimeos-typo3/Classes/Command/JobsCommand.php on line 51
Any hints? Thanks in Advance
Uli
Re: Error after Installation in TYPO3 12LTS / aimeos-typo3 23.10
Post by aimeos » 23 Feb 2024, 09:51
TYPO3 maintainers decided to allow a new major version of the Symfony console package (7.x) in TYPO3 12.4.11 which isn't backwards compatible due to changed return declaration for the execute() methods of commands.
Can you please update to aimeos-typo3:2023.10.x-dev and check if it works using the latest commit (ed25ebb899e921405a7c605b691017dd540556db)?
taunusweb
Post by taunusweb » 23 Feb 2024, 09:57
That worked! :)
Post by aimeos » 23 Feb 2024, 10:12
Thanks, a new version has been released now
