TYPO3 Installtool Compare DB whant always delete all tables
skydivematy
Post by skydivematy » 12 Apr 2016, 16:21
Hi Aimeos Team,
after installation of Aimeos Shop System, the TYPO3 installtool offerts always to delete all tables from DB of Aimeos Shop Extension.
The System is TYPO3 7.4.5 on PHP 7 with MariaDB.
This can't be normal? Or.
Regards
Matthias
Re: TYPO3 Installtool Compare DB whant always delete all tab
Post by aimeos » 13 Apr 2016, 12:24
This is a known problem:
https://github.com/aimeos/aimeos-typo3/issues/7
There's a bug report at TYPO3 Forge where you can vote for getting this fixed:
https://forge.typo3.org/issues/33136
skydivematy
Post by skydivematy » 13 Apr 2016, 14:11
OK, thank you for this hint. I had not seen this...
Regards
Matthias
